Character animation and voronoifracture issue
   3676   4   2
Hi, I have a character fbx and it works good and such, but the problem is that I need to have him fractured but keep moving. The fracturing works fine, but I only want it to fracture once since it is a heavy mesh, but to do that I can only make it work if I freeze-frame the animation and then fracture it. To make it keep moving, the fracture tries to happen every frame, which won't work.
I have been searching around for a while now and testing different setups, but I haven't come up with anything substantial, so I thought I would ask the pros! I know there are different nodes that do things like that (like point deform vop), but I can't seem to get a result. Any ideas are appreciated!
not really sure if that could help but you might find some tips in this tutorial.
cheers
This is a bit rough, but might give you some ideas.
fbx_fracture.hip (413.7 KB)
Fracture on Animated Character [www.youtube.com]
File available in youtube description
Mohan Pugaz
movfx
Thanks guys. I have revised the solution even more, but the problem of the fractured character not moving in the sim right remains.
Heres a link to the file and the character assets im using: .
Let me know what I'm missing!
