I can rendering with renderman but I can't find the renderman menu button on top-level menu.
   4458   3   1
No renderman shelf tool. No Preset Browser.
Here's my houdini.env.
RMANTREE=CProgram Files/Pixar/RenderManProServer-22.5
# htoa config start
PATH = “$PATH;CUsers/Weish/htoa/htoa-4.1.0_r2d54824_houdini-17.5.258/htoa-4.1.0_r2d54824_houdini-${HOUDINI_VERSION}/scripts/bin;CProgram Files/Pixar/RenderManProServer-22.5/bin;$PATH”
HOUDINI_PATH = “CUsers/Weish/htoa/htoa-4.1.0_r2d54824_houdini-17.5.258/htoa-4.1.0_r2d54824_houdini-${HOUDINI_VERSION};&”
HOUDINI_DEFAULT_RIB_RENDERER=prman22.5
HOUDINI_VIEW_RMAN=renderdl
# htoa config end
Houdini FX version 17.5.258
OS:win10 x64 pro
Set the renderman values as the first in sequence for ur variables (ahead of other variables- in this case Arnold)
For me the menu magically appeared after doing that.
Your config doesn't set RFHTREE or add RenderManForHoudini to the Houdini path.
follow the directions here:
https://rmanwiki.pixar.com/display/RFH22/Installation+of+RenderMan+for+Houdini [rmanwiki.pixar.com]
Fixed. Thank you so much!
