Extra number value in array?
   2388   4   1
So im getting alot of 0's inside a foreach loop when i store a value into an array,Why? Is there a way to just get the points i got inside the nearpoints function. I dont want to use removevalue function cause if i get a point in the array 0 i dont want to remove it.
vector lastpoint = point(0,"P",28);
vector pos = point(0,"P",25);
int area[] = nearpoints(0, pos,0.31);
f[]@distancenum;
i[]@areanum;
foreach(int p; area)
  setpointgroup(0,"TEST",p,1);
  vector currentpos = point(0,"P",p);
  float distancepoint = distance(lastpoint,currentpos);
  @distancenum[p] = distancepoint;
  @areanum[p] = p;
Edited by Shadowjonny - June 17, 2019 04:57:15
Screenshot (346).png (355.3 KB)
That's normal because you are assigning values into an array by index so the gaps are filled with 0s.
You can just store the resulting array like so:
i[]@pts = area;
animatrix3d
i[]@pts = area;
Works for inter not float? distancenum is float when i do @distancenum = area; I get {25.0,1.0,2.0,4.0,5.0}, i want to store the values i get from distancepoint.
Edited by Shadowjonny - June 17, 2019 06:36:57
use
append(@distancenum,p)
instead
ThomasRunning
use
instead
OMG!! of course that would work how did i forget about that function. -.- Thank you.
