Hi guys
So, if i have an attribute expression to manipulate the color (Cd) attribute
I want this attribute expression to create random colors but based on a random variations of a single color
So for instance if the main color i want is green
then i want the attribute expression to produce random shades of green
from the original green, so that i can have lime green, dark green, etc…
Thank you
Random Cd color from a main base color
2533 2 1-
- henrythejedi
- 61 posts
- jsmack
- 8178 posts
You might try randomizing in an hsv color space. You can use the hsvtorgb() function to convert the random hsv value to rgb color.
For example in an attribexpression, you might create 3 expressions for attribute Cd:
A range of (0.25, 0.5, 0.1) to (0.35, 0.9, 0.6) gives green colors. the components are hue, saturation, and value.
- random(@elemnum)
- fit01(self, chv('min'), chv('max'))
- hsvtorgb(self)
- henrythejedi
- 61 posts
jsmack
- random(@elemnum)
- hsvtorgb(self)
It works beautifully jsmack
Thanks so much for such detailed technical explanation
Now I can have a truly diverse forest vegetation using just one plant instance with this trick
Thanks a lot jsmack
