Attribute Wrangle Node : "output selection group "??
   2765   2   1
On Bindings tab Of Attribute Wrangle Node i haven't understood the option “Output Selection Group”(i have read documentation). So plz help me this .
- thank You
If there is a group already defined on the incoming of the wrangle and you specify the name of that group in the parameter you are speaking of;
That group will become highlighted as a group selection in both the geometry spreadsheet and in the viewport.
This can be handy as a visual aid for other operations.
P.S. Thanks for asking this question, otherwise I did not know of this option. I have had in the past the need for it, and as an aid wrangled my groups to a specific color to be able to see the group as a visual aid. Now that I know of this option, can do it more quickly.
Edited by BabaJ - June 25, 2019 13:11:25
More importantly it can highlight the group defined in the same wrangle/VOP if you specify the same name
