Emit light from an image sequence
   1649   1   0
Hi!
I want to create a material that can emit light from an image sequence. I created a principled shader, i used an image sequence for the emission color, but mantra only renders one frame, there is no animation.
Do you guys know how to solve this issue. That would help me a lot.
Thanks for helping !
you can remove all connections and set your emission texture path on the Principled Shader directly in Textures tab
if however you need to have something connected to the shader, then you need to wrap all the connected nodes into material builder node so that your parameter is promoted
then set your path to the sequence on the promoted parameter(s), only those can be animated unfortunately
