What's the "Real Time Toggle" button used for?
   4084   3   2
I notice there is an icon like a clock named Real Time Toggle in the left-bottom cornor.However,nothing is changed when it is pressed down except the playing speed of animation becomes slow.What's the function of this button?And when do I have to keep it down?
Edited by Middle-Earth - July 8, 2019 02:32:35
Moin,
… not exactly. According to documentation (that you have, of course, studied), it is (https://www.sidefx.com/docs/houdini/anim/playbar.html [www.sidefx.com] ) there to toggle between “do your simulation no matter how long it takes” (paraphrased) and “do whatever necessary to keep the set FPS rate”. “Realtime” in that sense means “stick to the set FPS rate”, whereas “do simulation and forget about FPS” can be slower - or much faster.
Marc
Good bye.
Thank you!That’s very clear!
For that explanation,I think turning this off may let computer run a little faster,right?
And one more question,which FPS does Real Time Toggle keep?I guess there is a place in houdini to set this FPS parameter,right?
Hi, anonymous user,
please do have a look into the documentation that accompanies this software. While it isn't perfect, it does answer a good part of your questions :-)
As for “letting the computer run faster”: This can not globally, generally be answered with “yes” or “no”, from my perspective the best response to your assumption is “erm … uh … I guess … no?”
Marc
Good bye.
