Why can't I inflate keyframing the Pressure Constrain Stuffness Slider ?
   2316   2   0
can you inflate as a animation using the Pressure Constrain Stuffness Slider ?
also I tried using the Constrain Vellum Property as shown in the video below
is an expression the only way to animate a value ?
or am I missing something trying to keyframe the value slider ? is that logic not the Houdini way ?
Most Joy
Thomas4D
“The Bruce Lee of XYZ”
you can directly animate Stiffness on Vellum Constraint Property DOP, no need to write the vexpression
you can also play with animating Rest Length Scale
Thanks Tamte Legendary
Most Joy
Thomas4D
