Multi sub object material equivalent
   2357   2   1
Testing a workflow switch between 3ds Max and Houdini, another step is discover how is possible in Houdini to assign multiple materials on the same object, the same way in max is obtained using multi sub object material.
I didn't find a specific solution, any hint in the right direction is welcomed.
The goal is later to export in fbx and import in a realtime engine.
https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/3DSMax-Lighting-Shading/files/GUID-D968CDD9-4C5D-489D-A311-ED7486FCD4AA-htm.html [knowledge.autodesk.com]
Edited by davide445 - Sept. 14, 2019 15:48:51
AMD Ryzen 5 2600X, 4x16GB 3200 Mhz, Kfa2 GTX 1070 EX 8GB, Windows 10 Pro, KDE Neon
Material node?
>>Kays
This one?
https://www.sidefx.com/docs/houdini/nodes/sop/material.html [www.sidefx.com]
Any tutorial how to use it?
