need more control while object follows a path
6314 5 1-
- wood78
- 6 posts
Is there any way to have more control over an object as it follows a path. It is limited from 0 to 1 and 1 being that it starts over on the path. I have an object that is covering a good distance and with the lack of freedom I have between 0 and 1, it causes my object to have an undesirable amount of velocity because of the distance it is covering in the time given for it to move along the distance of the path. Any help or suggestions would be great. :?
wood is good
- EigenAlex
- 639 posts
- edward
- 8080 posts
- stevenong
- 1634 posts
Hi there,
I hope the above helps!
Cheers!
steven
wood78Use a Resample SOP to resample the curve with the Maximum Segments parameter set to the length of your animation ($NFRAMES should work just fine).
Cheers!
steven
- wood78
- 6 posts
- Mistyk
- 5 posts
