PDG Manual Changes
   2025   2   1
Hi!
I have small PDG graph that grabbing models by one from disk, doing some basic stuff with it (UV's, materials etc.) Then I load geometry to /geo, in same hip file, where I have camera, lighting setup and render node.
So when I clicking on work items in topnet I see models in scene through the camera.
Here is my question. Basically I have only one angle for camera that is suitable for bunch of models but not for all, so I need to incorporate some manual camera controls and somehow save camera settings for current work item. Is there a way to change camera settings only for certain work items? How can I setup such thing?
Or mb there is a way to save hip file for each work item so I can change camera angles for needed models in different hip files and then render all hips through tops?
Thanks in advance
Hey,
the most straight forward solution I can think of is to use a split node to seperate those workitems with the different camera transform into a seperate stream. Then you should be able to create camera transform attributes and push those onto the camera.
I will try to build a simple example. In the meantime have a look at the split node example scene on how to split specific work items.
Saving differnt hipfiles is also possible but more complex I think. For that the houdini command server should be used. That requires some familiarity with the houdini python api.
Dome
Here is a simple scene which renders differnt cameras for workitem 1 and 3.
Cheers
split_camera.hiplc (505.2 KB)
