Basically what I want to is to go through a bunch of MDD files in a folder, for each file I do my thing in SOPs - producing animation of some length, and then save that animation as single Alembic file (one for each input file). Basically sort of a animation file converter.
What I'm struggling with is, how to generate different frame range on my ROP Fetch for each incoming work item (incoming MDD file).
What I want to do is for each input (input mdd file) work item - take frame range stored in it's file name, and set it on my ROP Fetch node to generate needed amount of frames.
I'm doing “All frames in one batch” on my ROP Fetch node, and this seems to be able to produce multi-frame Alembic files.
Before that I was trying to do single frame ROP Fetch node and specify frame range in my Alembic ROP node, but it did not work that way.. only first frame was rendered all the time.
Is this possible or am i approaching it completely wrong?
Here is my TOPs network.. I have two File Pattern nodes - one for MDD files and other for Obj file (I apply mdd animation on obj file). I combine them to have work items with both paths. :
