VDB: Fill interrior with Surface parameters
   6155   5   1
1. We have complex and closed poly with (for example) point Cd presented.
2. We convert it to VDB - with SDF and fog inside channels.
3. We need have Cd attrribute propagate from surface deeper into volume. Now it is possible just for limited voxel-layers around source poly-surface.
Which way can we elaborate such network? VDB Analysis node prepared closest_point vdb-channel over source ‘density’ channel, so we have all required data presented in scene.
Thank you
Anything that flies
Can you provide reference or something (file)
here you are, if it can help
to be true, I seem it will be simpler (for me) to write just a custom propagate sop dso
vdb_test.hipnc (222.3 KB)
Anything that flies
If you append a volume visualize sop, you can see by enabling ‘fill interior’ on your vdb from polygons, you've done exactly as you describe you want done. You can append a volume slice to take an even closer look.
Edited by mestela - Nov. 2, 2019 23:12:29
Ah. Ok, so it is just my undrestanding of documentation.
Thank you
Anything that flies
Ok, I tried such vdb and found, than renderman does not render them correctly, just used Cd channel as density, but it is more questions to PxrVolume shader, than to vdb files.
Thank you anyway
Anything that flies
