Capture geometry
   2949   6   1
Hello!
What could be the reason that when applying the capture geometry my geometry disappears? Here's how it goes https://dl.dropbox.com/s/fxzek5v5fq134s5/Screencast%202019-11-13.mp4?dl=0 [dl.dropbox.com]
your bonecapturelines SOP is giving a warning - what does it say?
Training Lead
www.sidefx.com
goldfarb
Hi Michael! I just saw the answer. Is this node implied? I attached
it's telling you that it can't find any capture regions - so that node in the Extra Regions parameter doesn't contain a capture region.
click the Operator Choose on the Extra Regions parameter and then select only the Bone objects that you want to use to capture your geometry.
Training Lead
www.sidefx.com
goldfarb
Did I understand you correctly? https://dl.dropbox.com/s/4s3flpngz2r2i42/Capture.mp4?dl=0 [dl.dropbox.com]
yes, this is correct…
whenever you make a change above the Stash SOP you must click ‘Stash Input’ to update it.
after that you should have you capture
Training Lead
www.sidefx.com
goldfarb
Thanks Michael! You are genius! :-)
