Does anyone know if we can control HDA´s parameters in the HDA Processor using TOPs attributes without hardcoding them in the parameters tab?
To clarify: my idea is to find HDAs in a folder, put them in attributes and then use the attribute “HDA path” to tell the HDA Processor which HDA to process (that´s working fine).
The next step is to fine-tune the HDA´s behavior with TOP´s attributes - but I can´t hardcode them in the parameter´s tab because I´m not using the same asset to process.
HDA Processor - Ctrl parms from attributes [SOLVED]
2669 3 1-
- guilhermecasagrandi
- 284 posts
- brooke_sidefx
- 391 posts
- 284 posts
BrandonAthanks for the reply! That´s what I thought, but I didn´t manage to get it to work. Do you have a working example?
Yes, this is possible. You can use an attribute to drive the HDA Path, and then create attributes that match the parameters on the HDA, and they will be automatically applied to the corresponding HDA parameter when the work item cooks.
I even tried the hdap_attribute, but It didn´t work….
- 284 posts
