Use geometry to deform other piece of geometry?
   2184   1   1
Hi folks,
Please take a look at the image below (.hip also attached)
What i would like to do is drop the sphere down, so that it deforms (dents?) the grid.
So my final result will be just the deformed grid without the sphere. Like a bowling ball pushed into a rubber sheet (minus the ball)
I understand that the deformation will depend on the resolution of my grid!
I know that to achieve this particular result there are easier ways, but i'm interested in this for general modelling techniques. For example, imagine you have a tube, then you use a smaller box to deform it by placing it inside the tube then push it through the tube wall. For example…..
Any suggestions would be gratefully received! ……….. D
grid_deform.hipnc (70.8 KB)
Check out this thread on cheap collision deform.
https://forums.odforce.net/topic/30917-cheap-collision-deform/ [forums.odforce.net]
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
