Inverted boolean selection
4388 5 0-
- JuliaAndrea
- 2 posts
Hello everyone!
I am not quite experienced with Houdini so apologise if my question might seem a bit obvious. I have this model with simple boolean fracture which I would like to invert but I can't figure out how. I have tried using a blast node but I don't exactly know how to do it and I am defo missing something.
Thank you in advance!
- vusta
- 555 posts
- JuliaAndrea
- 2 posts
- BabaJ
- 2168 posts
- vusta
- 555 posts
here's an extremely simple case to help you visualise the effect. Always use extremely simple setup to test anything.
So if you toggle between subtract and intersect, you'll see immediately the effect.
In your case, because your cathedral could be a very complexed model made up of floor, columns, walls, windows, arches…etc…etc…It is not ONE watertight model that booleans nicely.
As mentioned above, it's hard to decipher your problem without the file. Maybe after you merged in your cathedral, run a (default) boolean on that by itself to remove any self intersections and hopefully you get a ‘nicer’ homogenous model to then use in your next boolean with the spheres.
- vusta
- 555 posts
