I seem to have a problem being able to get the viewport(stage context) show an obj image through the emission attribute alone.
I have the viewport light tick for emission selected.
In sops I set point v@emissioncolor attribute to desired levels algorithmically. Leaving Emission Intensity to manual control on the shader.
In Karma, it works fine and I get the desired results showing and can control the intensity(of emission color) manually on the shader.
If I switch to Houdini GL, however it doesn't ‘see’ the emission attribute and only uses the default emission color of the shader.
Bug or some additional step needs to be done?
Emission Attribute for Houdini GL
5759 6 2-
- BabaJ
- 2162 posts
- jsmack
- 8177 posts
- malexander
- 5281 posts
The Houdini GLSL shaders only accept a small subset of attributes, and they're fixed: P, N, uv, Cd, Alpha. OpenGL was designed with a heavy emphasis on textures, not attributes, so there are only a limited number that can be passed to the vertex shader. More attributes and binding between shader stages slows down drawing, so we opted to keep the supported attributes lean.
Outside of lops you can get around this by adding the GL material attribute ‘gl_lit’ and using Cd as the emission color (or by making your own GLSL shader). But there's no way to make a USD preview material ignore lighting, to my knowledge.
- jsmack
- 8177 posts
twod
I tried to connect a usd primvar reader set to ‘displayColor’ to the emission input of the usdpreviewsurface, that did not work in HoudiniGL but does work in Storm and Karma.
- BabaJ
- 2162 posts
- malexander
- 5281 posts
jsmacktwod
Emission as a binding point is ignored. But you can do the opposite - bind a emissionColor primvar to diffuse.
- BabaJ
- 2162 posts
For my purposes the workflow solution for seeing scene as GL was to make use of the diffuse and specular parameter options on the USD lights.
A background image eventually going to be used in conjunction with geometry derived from it, but for iterative purposes needed to keep work done in GL for initial set up, before ‘fine-tuning’ in render/Karma stages.
With the lights specular turned off (set to zero), and diffuse adjusted to needs - provides my working set up.
