Hi, I've noticed export options for .bchan, and .chan out of CHOPs went away around version 17,18. I'm open to a few workflows, but basically. This was probably the most useful export for me.
1. .chan files can read into nuke, maya.
2. I can use .bchan and then convert it to a 32-bit float wave file, preserving the dynamic range of sound
So, other than read a .bclip into an older version of Houdini. Are there any conversion utilities or perhaps .. export flags on the .wav export? I could use the options.
Thanks in advance
What happened to .bchan export and/or how do I get it back?
1912 3 0-
- andrewlowell
- 539 posts
- tamte
- 9376 posts
andrewlowell
you should still be able to save .chan and .bchan, unless you are using apprentice (not sure about Indie or Edu)
EDIT: not sure what you mean by export options (the dropdown menu?), but houdini will save files based on extension, where .chan and .bchan are still valid formats
Edited by tamte - Jan. 13, 2020 00:05:11
- andrewlowell
- 539 posts
- tamte
- 9376 posts
