H18, "Quick UV Shade" SOP issue ...
   1420   1   0
Hello;
I added a "Quick UV Shade“ SOP to check a texture on my geometry and then I modified that texture in Photoshop.
Now in Houdini I can't see the changes I made on that texture!
There is no ”Reload“ or ”Update" button, so I deleted the texture path and I added it again, but I got same unchanged texture!
It seems Houdini keeps a texture in memory, and I should restart Houdini to reload texture file, right?
Is this a bug?
Thanks.
Edited by Masoud - Feb. 2, 2020 02:31:37
Masoud Saadatmand (MSDVFX)
Use the update textures menu option under the Render menu.
