Calling onScheduleStatic
   1339   1   2
Hello!
I'm trying to explore more of creating a scheduler with our farm software. I wanted to experiment using the onScheduleStatic. I can't seem to figure out how to call the onScheduleStatic on a submitJob without calling it directly.
I saw that I should be able to run this, but I get a False return value and none of my debug statements work under the onScheduleStatic function. I think my implementation may be wrong for this?
pdg.GraphContext().cook(True, pdg.cookType.StaticDepsFull)
Does a static cook of the whole graph. This consists of doing a GenerateFull, and then calling the onScheduleStatic implementation of the users custom scheduler.
Note that this is a fairly obscure cook mode, and will not work out of the box with stock schedulers.
Any direction would help!
Thank you!
Josh
Edited by joshm - Feb. 10, 2020 12:55:26
I added this to the submitAsJob function and it works!
node = hou.node(node_path)
node.executeGraph(True, True, False, True)
return node.getPDGGraphContext().cook(False, pdg.cookType.StaticDepsFull)
