offsetting/shifting keyframes in animation editor
   5435   9   1
in the animation editor, if I select some keys and enter ‘+100’ in the frame field, the keys all shift 100 frames ahead. If I enter ‘-100’, nothing happens.
How do I shift keyframes backwards in time?
thanks,Jasper
Use +- to offset them back in time +-100
nope
sorry, I should add: I've tried that as it's pretty obvious and it doesn't work. (+100)*-1 etc, also don't work.
druitre
nope
maybe try again, as that's how you do it +-100 should offset selected key values by -100 either if Frame or Value fields
Edited by tamte - Feb. 21, 2020 11:39:13
In Values it works, in Frames it doesn't. H17.5 & H18.
druitre
seems to work fine in builds I have currently installed (17.5.302, 18.0.380)
Hey druitre,
I encounter the same problem from time to time. Sometimes It is not working for me when multiple curves are selected.
One curve at a time should work. (looks like a bug)
Cheers
CYTE
Hi Tomas,
could it be you are selecting just one curve as CYTE is saying? In that case, I should've asked: ‘on all selected curves’.
And yes, I consider that a bug, I'll submit it.
cheers, Jasper
It's even more weird:
- one curve selected, everything works.
- two or more curves selected, everything works UP TO +-48 frames. At +-49 frames, it stops working. + it works normally, +- it stops working at 49.
