Hi to all,
I've created a rig, then to add the blendshape I'm just struggling to capture the shape into the rig. Seen some tutorials and also tried exploring the existing “simple Female Character”, but still cant to fix it. I've attached the HDA along this post which is a simple rig to test for fx. Moreover I've created a parameter of “Deflate” to the blendShape. Please someone look into it & give a solution.
Thanks in advance
Capturing BlendShape
1651 2 1-
- pksfx
- 41 posts
- malbrecht
- 806 posts
Works for me …
Simply connect the output of the blendshape node to the input of the deform-node to combine both morphing and deforming.
BTW: I would it helpful if you could either store geo into the file node (“lock” it) or provide the geo you are using alongside the asset … just a thought to make things easier. Sure, I can grab the geo from the stash node … but if I accidentally restash, it's all gone.
Marc
Marc
Good bye.
Good bye.
- pksfx
- 41 posts
