How to pattern match to assign materials in Solaris
   4045   2   0
Hi
I am trying to pattern match to assign materials in Solaris with the assign material LOP.
If my setup looks like this:
Primitives: /sopcreate1_box
MaterialPath: /materials/box_mat
All is fine. If I try to replicate how I used to do this before Solaris it would have looked like this:
Primitives: /sopcreate1_box*
MaterialPath: /materials/box*
And it would have worked. How to you mass assign materials to the same name of objects now? (box, box1, box 2 etc). It looks like I need to specify Material and object using CVEX or Vexpression but digging around I am a little lost. I have had a Hip file included. Thanks for any help.
OK What a plonker. I just realaized it needs to be like this..
Primitives: /sopcreate*_box*
I forgot to add a * after the sopcreate.
Edited by Mark Wallman - March 9, 2020 16:26:45
patternMatchingTest.hipnc (329.8 KB)
You can use pattern in Primitives parameter but not in Material Path. Looking at the hip file, there are only two materials, so you should not need to use pattern for the Material Path anyway. Try
Material Path: /materials/box_mat
and
Primitiveas: /sopcreate1_ball*
Material Path: /materials/ball_mat
Otherwise, could you attach a quick .hip example of how you used to do this before Solaris?
Hi Rafal
This is perfect. It was user error on my part getting it wrong.
Mark
