Add Sop Handles Limit
   1617   3   1
Houdini Brethren / Sistren:
So I've got an Add Sop with 100 points, but I'm only seeing handles for about the last 20, which makes manipulating the earlier points extremely cumbersome.
I've tried to google the issue but maybe I'm lacking the right jargon to find a solution. I've only found that I can select / deselect from the 20~ points with existing handles.
I've attached a screenshot.
Working in v18.0.348
Any help would be superb!
Screenshot 2020-03-13 20.56.54.png (2.3 MB)
you should contact support team9app
9aps [androidsadhu.blogspot.com]
9apps
Edited by christon - March 18, 2020 01:52:09
christon
You're probably right, thanks!
Also going to try the latest release.
Have you had the same problem, by chance?
it's simply how many handles Add SOP has
the handles are not dynamically created, so you can't get more than that
there is a need for some tool that can use Viewport Python States to create handles dynamically, either for Add SOP or also more modern Curve SOP or other
