Rotate line to be align to axis
   2566   4   1
I need some help to solve this.
I want to be able to find the amount of rotation necessary to align this line to the axis.
For example, the amount to find here is “14.25”, but proceduraly.
Thank you
Edited by RonanCroyal - April 3, 2020 11:17:16
RotateToAlignToAxis.rar (20.7 KB)
You can use dot product to get degrees and compenste with a Transfrom node.
RotateToAlignToAxis.hipnc (198.1 KB)
what the ???
to me it's a triangle….use trig:
soh cah toa
tan x = opposite/adjacent
01) get the N with polyframe (the N represents the hypotenuse of said triangle)
02) then take advantage of this N
vu_RotateToAlignToAxis.hiplc (156.3 KB)
akirasun_sh: It doesn't work properly on other line. Thank you anyway
vusta: What's up with the “what the ???”.
If you refer to my question, I'm not really good at math, it might seem like a stupid question for you, but yeah, I wasn't able to figure that out by myself.
And for the triangle in my scene, it was just a test I did because i thought this could help.
Anyway, your solution works perfectly ! Thanks a lot
RonanCroyal
i was alluding to the fact that it was a triangle, no need to involve astro physics or chemical engineering to solve the problem…like the cult of overcomplicators i keep seeing…not attacking your question at all.
Edited by vusta - April 4, 2020 05:26:32
