My first serious project has hit the buffers and I wonder if i could please get some pointers to move forward. I need to form a set of groups dynamically based upon duplicate attribute values. Each group must consist only of duplicates or only a single primitive if there are no duplicates. Ideally I wish to store the result in another attribute but forming a group for each set of duplicates will suffice. How to get this done most efficiently? I need a “Group by Duplicate attribute” SOP or VEX wrangle equivalent but just cant quite get the code logic right as my screenshot shows.
Specifically in the below annotation I need the values listed in perimInt (right column) to be allocated a sequential mesh ID (2nd from right column) based upon descending order of size ( these relate to perimeter size of each primitive by colour) , so primitives 0-1 should be meshID 0, primitive 3 is meshID 1, primatives 3-4 is MeshID 2 etc
I have tried the partition SOP to create the groups but the rule syntax is problematic if you do not know in advance the attribute values you are grouping against. I am a VEX newbie so have tried to write my own wrangle but have underestimated the programming complexity of the task which i initially thought would be straightforward. Any helpful suggestions gratefully appreciated.
How to create groups based upon duplicate attribute values [SOLVED]
3703 3 0-
- PaulJChris
- 7 posts
- PaulJChris
- 7 posts
- tamte
- 9384 posts
- PaulJChris
- 7 posts
