Recently got back into Houdini after months of not using it. Since then, I've completely forgot how to set Houdini up such that it starts up with both the Scene View and Redshift IPR view side by side one another. To clarify, I mean to sandwich the IPR view in between the Scene View and the Leftmost Vertical Toolbar. Cant seem to snap the IPR window into place.
After that I'd just save the workspace, but I can't seem to get past step 1.
Workspace/Redshift questions
2152 1 1-
- chrisrutherford
- 3 posts
- robsdesign
- 240 posts
Hi, you can use Split Pane tab (left/right up/down) using the drop-down menu (Triangle/Arrow top right of each pane) or short-cuts. You can add tabs using the plus (+) icon.
I've attached a hip file and desktop I often use for basic stuff.
I've duplicated certain tabs so I can (for example), view through camera on left pane, move light on right pane. Or, view Redshift render on right pane, work with materials on left pane. etc.
Rob
Rob
