I am very new to Houdini and am following the beginner soccerball tutorial. I create a box and type s > 4 > n to select all primitives. I then go to Model > Polygon > Polygon Extrude and enter Distance: 0.4. The box completely disappears and I cannot get it back.
Please help.
Object disappears during Polygon Extrude action
4338 6 1-
- repowell
- 1 posts
- vusta
- 555 posts
- anon_user_38315714
- 340 posts
https://www.sidefx.com/tutorials/houdini-foundations-book/ [www.sidefx.com]
Page 48. Note that in this tutorial, they map the platonic onto a sphere with the ray node, which helps maintain the spherical shape. The book is written for an older version of Houdini, but works perfectly in version 18.
Similarly, see
https://vimeo.com/142494487 [vimeo.com]
Similarly, see
Edited by anon_user_38315714 - May 22, 2020 21:35:10
- Ra138
- 4 posts
In part 9 step 02
Once I disconnect the 3 lights. Then again connect them as written in pdf. The ball isn't there. I tried to check display of all the nodes but unable to figure out.
Maybe I have to undo and start over.
Edit
It's done. So basically when we add reference node. Then choose soccerball_anime.usd, we can see the ball again.
The previous ball can be seen if we on display of karmarendering node.
Edit
Edited by Ra138 - May 16, 2023 11:23:48
- Ra138
- 4 posts
- Ra138
- 4 posts
