Hi!
I wanted to create a curve, point by point and use a crease to decide what point should crease more than others once I subdivide. I cant get the creases to work. Is it possible it's not made for curves, only for geo?
-Olivier
crease a curve?
1859 2 0-
- olivierth
- 1184 posts
- Konstantin Magnus
- 720 posts
Hi Olivier,
I am not sure if the resample node supports weights directly but you could either set point weights (Pw) on a NURBS curve or bevel points before resampling the curve.
- olivierth
- 1184 posts
