Karma optional parameters - Render tab
   1929   2   1
Hey there. How do I add or where do I find the Render settings at the geometry node level for Karma? I see them for Mantra such as: “Render Points as Spheres”, but obviously changing that setting has no influence in Karma. Currenly my points are being rendered as giant spheres in Karama and I cannot find the setting to change it.
Thank you!
Karma doesn't use geometry nodes.
The geometry render settings are found on the render geometry settings node.
https://www.sidefx.com/docs/houdini/nodes/lop/rendergeometrysettings.html [www.sidefx.com]
Awesome thank you!
