We usually do UV's in Maya but occasionally I need to do something UV related in Houdini and I forget every time which node to use!
Do I want to UV_Project or Uv_Texture?
Do I want to UV_Unwrap or UV_Flatten or maybe UV_Pelt.
It makes me laugh every single time but this joke is kinda stressy when I'm in a rush.
Clean up the UV SOP Nodes List/Workflow?
4205 4 1-
- Wren
- 532 posts
- anon_user_38315714
- 340 posts
- jsmack
- 8178 posts
- 340 posts
Uv texture is generally used on a line or curve as you are creating the model. There isn't really an equivalent of that in maya that I know of. If you want to do seams on a finished model, it is uvflatten. If you want spherical, cyllindrical or planar mapping, use uvproject. Uvpelt is mostly an older and less useful way of pelt mapping.
Edited by anon_user_38315714 - Aug. 12, 2020 21:47:39
- Midphase
- 833 posts
I'm far from a UV expert, but I did put together a short tutorial a while back based on what I know about using UV's in Houdini:
>>Kays
