For example, I want to select a bunch of static mesh assets in UE4, and use Houdini to generate low-res mesh LODs or collisions to overwrite original assets.
Is there any way to do this currently?
Can I use Houdini Engine as a batch assets proccessor in UE4
2853 2 1-
- EricSheng
- 159 posts
- hektor
- 54 posts
- Len
- 135 posts
I don't think you'll ever get an HDA alone to overwrite the original assets but otherwise that should all be do-able from a single HDA using a multi-parm input, among other techniques. You'll need to make sure the HDA is an object-level one, not SOP, as you need distinct objects generated in UE, not a merged single one.
