what is a common method for rendering out lists of frames
11102 14 3-
- andrewlowell
- 539 posts
- VisualCortexLab
- 509 posts
I'd say I'd use variables in ROP … and with a script I'd change ‘em accordingly…
like some buttons in a HDA which sets, let’s say $START and $END, accordingly to some predefined choices (1 to 240) or user defined with parameters… how that sounds?
cheers
cheers
JcN
VisualCortexLab Ltd :: www.visualcortexlab.com
- wolfwood
- 4344 posts
- andrewlowell
- 539 posts
- VisualCortexLab
- 509 posts
oh yeah … I thought about merge at first… but I thought you were looking for frame ranges on certain passes only… not all passes together..
JcN
- andrewlowell
- 539 posts
yeah I need to explore the frame dependency after this next render here but I'm guessing with different wiring and merges it can render certain stuff from ones vs others with the “strict” on the nodes.
I just didn't want to copy all the passes 20 times just to render out individual frames
It sure would be nice if there was a “strict” on a merge though (to make the ones above it only do that) so multiple merges could be used in different combinations from the same stuff. The Render Dependency will probably do most of the same thing though.
- kuba
- 345 posts
andrewlowell
Yeah, say I have tons of render nodes for different passes. If I just want to re-render a bunch of specific frames (not in order). What is a common method?
Hey Andrew,
That is just a quick attempt. Please have a look at this otl and the hip file. Is that what you were thinking of? Would be grate if you could test so I can eliminate any potential problem and post it to the exchange.
Worth of notice is that I had to embaded the hscript in otl using
opdef:.?selected.cmd
Funny but while doing some test in textport this script worked fine, but the same thing running from pre/post-render script, instead each, specified frame, printed every time only the last one. Looks like a bug to me…
Anyway, hope that helps
cheers
kuba
- andrewlowell
- 539 posts
- Antoine Durr
- 321 posts
andrewlowellmake a pair of scripts: one that takes a hipfile name, a rop name, and a frame number, and then a second one that has a couple of foreach lines in it, and inside the foreach invoke the first script appropriately. For example:
set HIPFILE = “/my/hipfile.hip”
set ROPS = “BgDiff FgDiff BgSpec FgSpec”
set FRAMES = “1 4 22 67 102 103 104”
foreach rop ($ROPS)
foreach frame ($FRAMES)
render_hip_file $HIPFILE $rop $frame
end
end
That's obviously pretty brute-force and not particularly efficient. You'd improve on it by having a script that you can source within your running Houdini session. But that's the basic idea, anyway.
– Antoine
- andrewlowell
- 539 posts
yeah when Python comes out I'm going to try to do a scripted asset that will take in every light that shines on an object/rig and generate render passes for each light etc. Going to try to stay away from the heavy scripting until then so I don't have an extra script floating around in my head but I definately get the idea.
- andrewlowell
- 539 posts
I think your asset is really cool Kuba .. this should definatly come in handy … thanks a bunch.
I didn't find any errors etc and tried it out on different takes etc. Here's a few suggestions.
a. hide the default subnet parameters
b. I would think that frame by frame rendering would only be useful for renders that is 100% history independent, meaning no particles dynamics, etc. Otherwise the take would have to reload/calculate for each different frame which would take a long time. I don't know if there's any way to do a node by node option for your asset but that would be really great if you could.
- kuba
- 345 posts
Here is a small update
I changed slightly the script so there is an option to select multiply ROPs, but don't know why I'm having problems with reselecting each ROP after first selections. I'm using in the otl for the Type: OperatorList and for the Op filter: Any ROP. should work fine to me, but it doesn't. So sometimes I have to type each ROP manually.
Please note you can't use wildcards for that.
I added to the render script -l flag which sets from default ROP by ROP to Frame by Frame rendering for dependency networks. Is that what you thought about?
cheers
kuba
andrewlowell
Do you mean, “Render” and “Render Control..” buttons - I think in ROPs you can't hide them
cheers
kuba
- pbowmar
- 7046 posts
andrewlowell
This is the sort of thing that really should be done in the shader, otherwise you're re-doing a huge amount of rendering needlessly. I'm not saying it's that easy right now to do it, but it's possible
Basically, you output deep rasters for each light's Diffuse and Specular (separately). The biggest problem is, you have to hard-code into the shader or VOPnet the max number of lights you can output.
Hopefully some day SESI will ship a single standard base shader VOPnet that has all these useful deep rasters as standard, and then all other shaders are built on top of the standard VOPnet so that you always get these deep rasters. Obviously, you don't have to actually use them (i.e. write them to disk) but unless the shader supplies them you're hosed.
Peter B
Peter Bowmar
____________
Peter Bowmar
____________
- digitallysane
- 1192 posts
pbowmarThat would be *SO* useful.
- andrewlowell
- 539 posts
