Using sound to change light parameters for a dalek's eye?
   2294   3   1
Hello, I just found about about Houdini. I'm interested in transferring to Houdini from a Cycling74 Max patch.
The patch changes the color of material regions on a ‘dalek’ object when a voice rises above a particular level from a mic input, so that the dalek's eye flashes on and
off. The cycling74 patch also vocodes the voice input, which I show in the attached image.
In Houdini, how would I import a voice file and set it up to modulate a light?
You would use CHOPs.
Here is a tutorial video that should give you an idea of how the whole thing works:
https://www.sidefx.com/tutorials/audio-driven-animation-1/ [www.sidefx.com]
>>Kays
CHOPs also supports MIDI - so if your max patch can send midi you can use that to drive whatever you'd like
Training Lead
www.sidefx.com
Gee that's great, thanks guys! This will be fun, Im looking forward to it
