Hi!
What is a way to export attributes from geometry to a frame range for a work item?
Each incoming geometry has its own animated frame range, I create this attribute at the detailed level and I want to pass this attribute to the ROP Alembic Output node to write animation to my alembic in the specified frame range. But all alembics are saved with only one frame range, which I don't need.
Attributes to Frame Range
7059 5 0-
- dtempcyer
- 326 posts
- dtempcyer
- 326 posts
- tpetrick
- 616 posts
- dtempcyer
- 326 posts
- tpetrick
- 616 posts
On the Geometry Import there's a toggle for “Evaluate With Work Item Attributes”. You'll need to turn that on if the SOP network you're importing uses any PDG work item expressions, like @pdg_input. When that toggle is enabled the SOP network is recooked for each work item, rather than only cooked once.
- dtempcyer
- 326 posts
