Creating lowres cut out of texture / or 2d concave hull
   2245   4   1
Hey guys,
I've stuck and bit and need o to borrow your brain.
Have a 2D texture:
And I want to create low res cut out of it:
Unfortunately, trace sop gives me very high res results. When I increase step size, the edges of the outline will start going through texture. The same resampling of trace sop wouldn't give me results like in the picture. Basically, I want to create a 2d concave hull around that texture.
Any guidance?
Hello ,
I think you could use a refine node , set it to unrefine , from u 0 to 1 , play with the threshold
then maybe a polyexpand 2D…
Resample and polyexpand2d for me.
cut_out.hipnc (78.2 KB)
after making some test , in fact resample first , polyexpand then unrefine give something really close to your shape
Edited by Benjamin Lemoine - Nov. 22, 2020 07:11:57
Thanks Benjamin and Konstantin. It works perfectly! Really cool!
