Add new node under the current selection through python.
   5199   3   2
Hi there,
Is there an easy way to do this through python? I just want to create a new node and attach it under the current.
I have a script that creates the node fine but it seems like a huge pain to wire that new node up. Especially in situations like this.
Everything I'm doing seems really tacky, just kinda hoping I was missing an easy option.
selectedNode = hou.selectedNodes()[0]
parentNode = selectedNode.parent()
newNode = parentNode.createNode("SomeNode")
newNode.setInput(0,selectedNode,0)
newNode.moveToGoodPosition()
#This part breaks things :(
if len(selectedNode.outputs()) > 0:
    outNode = selectedNode.outputs()[0]
    outNode.setInput(0,newNode,0)
newNode.setSelected(1,True,False)
newNode.setDisplayFlag(True)
Thanks,
Pete
Edited by peteski - Nov. 24, 2020 18:09:26
Screen Shot 2020-11-25 at 10.02.20 am.png (45.6 KB)
It's indeed tricky to wire nodes mid-stream. I wrote some utility functions you can adapt to your use perhaps:
def connectSelectedNodesToNewNode(newNode, selNodes, connectToNearestNodeIfNoSelection=False):
    category = newNode.type().category()
    isSop = category == hou.sopNodeTypeCategory()
    isVop = category == hou.vopNodeTypeCategory()
    selectedNodes = selNodes
    nodecount = len(selectedNodes)
    if nodecount == 0 and connectToNearestNodeIfNoSelection:
        editor = hou.ui.paneTabUnderCursor()
        if editor:
            nearestNode = findNearestNode(editor)
            if nearestNode:
                selectedNodes = [nearestNode]
                nodecount = 1
    if nodecount > 0:
        ninputs = newNode.type().maxNumInputs()
        if ninputs > 1:
            #sort nodes from left to right and connect by position
            selectedNodes = sorted(selectedNodes, key=lambda n: n.position().x())
        if len(selectedNodes) == 1 and (isSop or isVop):
            selectedNode = selectedNodes[0]
            outputConnectors = selectedNode.outputConnectors()
            inputConnectors = newNode.inputConnectors()
            if selectedNode.type().name() == 'subnet':
                outputConnectors = [outputConnectors[0]]
            if isSop:
                for i in range(min(len(outputConnectors), len(inputConnectors))):
                    newNode.setInput(i, selectedNode, i)
            if isVop:
                outputIndex = 0
                outputDataTypes = selectedNode.outputDataTypes()
                inputDataTypes = newNode.inputDataTypes()
                numOutputDataTypes = len(outputDataTypes)
                numInputDataTypes = len(inputDataTypes)
                for i in range(numInputDataTypes):
                    if outputIndex == numOutputDataTypes:
                        break
                    if outputDataTypes[outputIndex] == inputDataTypes[i]:
                        newNode.setInput(i, selectedNode, outputIndex)
                        outputIndex += 1
        else:
            index = 0
            for i in range(nodecount):
                if selectedNodes[i].type().maxNumOutputs() > 0 and index < ninputs:
                    newNode.setInput(index, selectedNodes[i])
                    index += 1
def createNewNode(editor, nodetypename, parms=None):
    import nodegraphutils as utils
    pwd = editor.pwd()
    path = pwd.path()
    context = pwd.childTypeCategory().name()
    if pwd and path and context:
        nodetype = hou.nodeType(pwd.childTypeCategory(), nodetypename)
        if nodetype:
            selectedNodes = hou.selectedNodes()
            with hou.undos.group("Create New Node: " + nodetype.description()):
                pos = editor.cursorPosition()
                newNode = hou.node(path).createNode(nodetypename)
                if parms:
                    if isinstance(parms, dict):
                        for i, (key, value) in enumerate(parms.items()):
                            newNode.parm(key).set(value)
                    elif isinstance(parms, types.StringTypes):
                        hou.hscript("oppresetload " + newNode.path() + " '{0}'".format(parms))
                connectSelectedNodesToNewNode(newNode, selectedNodes)
                size = utils.getNewNodeHalfSize()
                pos[0] -= size.x()
                pos[1] -= size.y()
                newNode.setPosition(pos)
                newNode.setSelected(True, clear_all_selected=True)
                if nodecount != 0:
                    if context != "Driver" and context != "Dop" and context != "Shop" and context != "Chop" and context != "Vop":
                        if hasattr(newNode, "setDisplayFlag"):
                    if context != "Object" and context != "Driver" and context != "Dop" and context != "Shop" and context != "Chop" and context != "Vop" and context != "Lop":
                            newNode.setRenderFlag(True)
                return newNode
def objectMergeFromSelection(uievent):
    with hou.undos.group("Object Merge From Selection"):
        editor = uievent.editor
        currentPath = editor.pwd().path()
        currentNode = hou.node(currentPath)
        selNodes = hou.selectedNodes()
        for node in selNodes:
            mergeNode = currentNode.createNode("object_merge")
            mergeNode.setName("IN_" + node.name(), unique_name=True)
            mergeNode.parm("objpath1").set("../" + node.name())
            if len(selNodes) > 1:
                pos = node.position()
                pos[1] -= 1
                mergeNode.setPosition(pos)
            else:
                size = mergeNode.size ( )
                pos [ 0 ] -= size [ 0 ] / 2
                pos [ 1 ] -= size [ 1 ] / 2
                mergeNode.setPosition ( pos )
def objectMergeOutputConnections(uievent):
    import math, re
    import toolutils as tutils
    with hou.undos.group("Object Merge Output Connections"):
        sourceNodes = selNodes
            connectedNodes = tutils.findConnectedNodes(node, 'output', None)
            outputsReplaced = []
            newNullNodes = []
            newOutputNodes = []
            outputIndices = []
            childrenNames = []
            childrenNodes = []
            outputs = node.outputConnections()
            for o in outputs:
                outputIndex = o.outputIndex()
                outputNode = o.outputNode()
                if outputIndex not in outputsReplaced:
                    outputsReplaced.append(outputIndex)
                    outputIndices.append(outputIndex)
                    outputName = o.inputLabel().replace(' ', '_').upper()
                    re.sub(r'\W+', '', outputName)
                    newNullNode = currentNode.createNode("null", outputName)
                    newNullNode.setInput(0, node, outputIndex)
                    mergeNodeName = newNullNode.name()
                    mergeNode.setName("IN_" + mergeNodeName, unique_name=True)
                    mergeNode.parm("objpath1").set("../" + mergeNodeName)
                    newNullNodes.append(newNullNode)
                    newOutputNodes.append(mergeNode)
                outputNodeName = outputNode.name()
                if outputNodeName not in childrenNames:
                    childrenNames.append(outputNodeName)
                    childrenNodes.append(outputNode)
            lowestPosY = 0
            outputCount = len(outputsReplaced)
            for index, newNode in enumerate(newNullNodes):
                outputIndex = outputIndices[index]
                xoffset = math.ceil((outputCount - 0) / 2) - outputIndex
                yoffset = outputIndex + 1
                pos[0] -= xoffset
                pos[1] -= yoffset
                pos[1] -= min(3, outputCount)
                lowestPosY = pos[1]
                newOutputNodes[index].setPosition(pos)
            for o in outputs:
                inputIndex = o.inputIndex()
                outputNode.setInput(inputIndex, newOutputNodes[outputIndex])
            maxPosY = -999999999
            for connectedNode in connectedNodes:
                maxPosY = max(maxPosY, connectedNode.position().y())
            dist = lowestPosY - maxPosY
            minOffset = 2
            if dist < minOffset:
                diff = minOffset - dist
                    pos = connectedNode.position()
                    pos[1] -= diff
                    connectedNode.setPosition(pos)
def objectMergeInputConnections(uievent):
    import math, re
        sourceNodes = []
            inputNodes = node.inputs()
            for n in inputNodes:
                if n not in sourceNodes:
                    sourceNodes.append(n)
        for node in sourceNodes:
            newNullNodes = []
            newOutputNodes = []
            outputIndices = []
            childrenNames = []
            childrenNodes = []
            outputs = [output for output in outputs if output.outputNode() in selNodes]
            for o in outputs:
            lowestPosY = 0
                pos[0] -= xoffset
                pos[1] -= yoffset
                lowestPosY = pos[1]
            for o in outputs:
            minOffset = 2
                    pos[1] -= diff
Edited by animatrix_ - Nov. 25, 2020 01:37:59
Wow, that’s amazing!
It’s lot trickier than I thought it would be.
My code will actually unwire random things if used with a merge underneath so it’s kinda bad.
Thank you so much for that!
Feel free to ask SESI to add some utility functions to Python HOM for these so we can make our lives easier
