I'm new to Linux. I got houdini working, so thank god for that.
On Side Effects installation FAQ it says to
“You will need to source houdini_setup in each shell that you run Houdini. You can add the following code to your .login file to automatically do this
pushd /opt/hfs8.2.13 <- use the build version that has been installed
popd”
where is this login file located or do i need to create it. thanks in advanced
Linux .login file question
4783 3 1-
- jerwhitehurst
- 9 posts
- Pagefan
- 519 posts
- pbowmar
- 7046 posts
It's in your home directory. Anything with a dot in front is “hidden” so if you're in a shell, do this:
ls -al
the -a will show all files including hidden ones. If you don't see a .login file then you can create your own. This file will be sourced every time you log in to your computer.
Peter B
ls -al
Peter B
Peter Bowmar
____________
Peter Bowmar
____________
- jerwhitehurst
- 9 posts
