H17 Vellum Masterclass - how to animate single points inside dopnet?
   5762   1   0
Very interesting masterclass, I have a specific question:
Setup: a string attached to the ground.
How to animate the top point from inside the Dopnet? (I can't use a simple pin to target constraint).
The Sop Solver update at the starting frame only, when I set the point wrangle to write to specific group (tip).
However when I apply the same operation to all the points, the evaluation and update would happen on each frame.
At around 1:24:10 in the Masterclass, the instructor uses a geometry wrangle to write to the attribute v@air driving a pop wind
Is this the only way to arbitrary move around points inside a vellum dopnet?
https://youtu.be/NwabG-znu9Y?t=5050 [youtu.be]
Edited by Andr - Dec. 8, 2020 04:10:49
test vellum sop solver.hiplc (382.4 KB)
test example.JPG (107.4 KB)
vellum masterclass.JPG (128.9 KB)
Andr
nobody?
