Hi everyone,
I have a question with a simple code in vex.
I would like increment a index every n frame. For this I use a modulo in condition (if).
My code looks like that:
@Index = 0 ;
if(@Frame%20==0){
@Index +=1;
But with this, houdini dont keep value of my increment. For frame between F0 to F19 index =0 for F20 =1 for F21 = 0 for F40 = 1; etc...
If you have any idea, I would like to know.
Thanks everyone !
Increment only 10 Frame with Vex
6892 3 0-
- BastienPetitTestucci
- 4 posts
- jerry7
- 680 posts
- BabaJ
- 2164 posts
The reason is because your not telling Houdini to 'keep' the previous value. For example, at the Frame numbers 21 to 39 your code doesn't define what @Index value should be. So in Houdini when you have an attribute present but has not been defined with a value, most attributes default to a value of 0. So once you get to Frame 40, your only adding 1 to 0.
When you were at frame 20, it assigned @Index as 1 ONLY when it was at that frame. You have to think of how Houdini works differently since you are thinking values persist. Values only 'persist' if you code it in a way so that they do actually persist. Which is why jerry7 example works (if you change @frame to @Frame).
If your in a situation in which things get too complicated or are hard to manage and you can't think of a way to code for values to 'persist', you might want to learn how to use a solver sop.(your original code would work inside a solver sop, if you wire the nodes right)
Edited by BabaJ - Dec. 20, 2020 16:25:54
- vusta
- 555 posts
