Python States and Handles
   4087   6   0
some questions about the python states and how to deal with handles properly.
1. The python state handle example creates a static and a dynamic handle. when You drag the static xform handle the connected parameters get a direct connection to the handle, as soon as You move the handle You, the connected parameters are highlighted in the parameter window and update during interaction.
I would like to have this behavior with a dynamic handle as well, but I could only come up with a slightly looser connection, by adding updates to the "onHandleToState" and "onStateToHandle" methods. Is there a better way to do this. Best would be to have it to behave the same way like a static handle.
2. I want to align the handle to a specific point on a input curve. The curve has a rot attribute with the rotation vector in it. I added a method to set the pivot on the handle. Now I want to call this method as soon as I enter the state, but could not find a way. the "onEnter" method seemed to be the right point for this, but i could not get access to the parameters of the handle and the node, the state is working on.
I called the methods on the "onHandleToState" and "onStateToHandle" methods but this does not work right and feels just wrong . The handle is transformed correctly as soon as I move it slightly.
Is there a way to call this initial method as soon as the states is entered?
State:          handle a
State type:     handle_a
Description:    handle a
Author:         mmatzeder
Date Created:   December 31, 2020 - 09:53:26
# Usage: Make sure to add 6 float parameters to the node:
# newparameter, newparameter2, newparameter3, newparameter4, newparameter5, newparameter6.
# Select node and hit enter in the viewer.
import hou
import viewerstate.utils as su
def positionHandle(node, parms):
    parms["px"] = node.node("Out").geometry().points()[0].position().x()
    parms["py"] = node.node("Out").geometry().points()[0].position().y()
    parms["pz"] = node.node("Out").geometry().points()[0].position().z()
    parms["pivot_rx"] = node.node("Out").geometry().points()[0].attribValue("rot")[0]
    parms["pivot_ry"] = node.node("Out").geometry().points()[0].attribValue("rot")[1]
    parms["pivot_rz"] = node.node("Out").geometry().points()[0].attribValue("rot")[2]
class State(object):
    def __init__(self, state_name, scene_viewer):
        self.state_name = state_name
        self.scene_viewer = scene_viewer
        self.xform_handle = hou.Handle(self.scene_viewer, "Xform")
    def onEnter(self, kwargs):
        self.xform_handle.show(True)
        print self.xform_handle
    def onHandleToState(self, kwargs):
        """ Used with bound dynamic handles to implement the state
        action when a handle is modified.
        node = kwargs["node"]
        handle = kwargs["handle"]
        parms = kwargs["parms"]
        mod_parms = kwargs["mod_parms"]
        prev_parms = kwargs["prev_parms"]
        ui_event = kwargs["ui_event"]
        self.log(parms)
        if handle == self.xform_handle.name():
            node.parm("tx").set(parms["tx"])
            node.parm("ty").set(parms["ty"])
            node.parm("tz").set(parms["tz"])
            node.parm("rx").set(parms["rx"])
            node.parm("ry").set(parms["ry"])
            node.parm("rz").set(parms["rz"])
    def onStateToHandle(self, kwargs):
        """ Used with bound dynamic handles to implement the handle
        action when a state node parm is modified.
            parms["tx"] = node.parm("tx").evalAsFloat()
            parms["ty"] = node.parm("ty").evalAsFloat()
            parms["tz"] = node.parm("tz").evalAsFloat()
            parms["rx"] = node.parm("rx").evalAsFloat()
            parms["ry"] = node.parm("ry").evalAsFloat()
            parms["rz"] = node.parm("rz").evalAsFloat()
        self.log(parms)
def createViewerStateTemplate():
    """ Mandatory entry point to create and return the viewer state
        template to register. """
    state_typename = kwargs["type"].definition().sections()["DefaultState"].contents()
    state_label = "handle a"
    state_cat = hou.sopNodeTypeCategory()
    template = hou.ViewerStateTemplate(state_typename, state_label, state_cat)
    template.bindFactory(State)
    template.bindIcon(kwargs["type"].icon())
    template.bindHandle( "xform", "Xform")
    return template
I attached a little hip with embedded assets, thanks for Your time
Edited by sanostol - Dec. 31, 2020 07:06:31
handle_a.hipnc (175.3 KB)
Hello, is there a way to position a dynamic handle as soon as the state is entered? It seems to be not possible. I hope I'm wrong, but the "onEnter" method does not have access to the parms of the handle and the handle itself
kwargs only contains 'node', 'state_flags', state_parms' and 'state_name', state_parms is empty
so there is no way to position the handle correctly as soon as one enters the state
In your example from the first post you can call self.xform_handle.update(True) in OnEnter. That triggers OnStateToHandle where you can position your handle based on your own logic.
thank You, but does not work here, I still have to touch the handle to run the OnStateToHandle
Yeah, sorry - looks like you don't have to use immediate mode. Just
self.xform_handle.update()
At least for me it's working (see attached)
Are you on Win or OSX/Linux? I see couple of issues on updating the viewport on OSX but handles updating usually working fine.
handle_a.hipnc (146.3 KB)
Great, works fine, thank You!
Where the hell did You find that
I'm on Linux/W10.
Just had the same requirements for my state
You can check this one: https://www.sidefx.com/docs/houdini/hom/hou/Handle.html [www.sidefx.com] there are some other useful methods
xform_handlefrom your example is basically object of this class.
Sometimes I see some issues regarding updating viewport (on my OSX machine especially) but I think it comes from qt side of Houdini not from the states api.
