Hi guys!
Been struggling a bit with this tutorial as the sop solver is complaining that the data type of the input for the sop solver is wrong. Does anyone know what the problem would be? https://100001.onl/ [100001.onl]
I've basically converted a grid to a rigid bodied object and deleted everything apart from the first node generated in the autodopnetwork. I've then connected a sop solver to the rigid body object (inside the autodop) but its complaining that the data type is wrong. All help appreciated! I'm assuming the sop solver has evolved a bit since the tutorial was made so any pointers as to how its changed would also be gratefully recieved. Thanks!
Peter Quint's attribute transfer 2 tutorial
3726 0 0-
- Hauslabuland
- 2 posts
