Houdini Engine not passing pscale through correctly to UE
   3354   4   0
I have a tool that is building some geometry, along with scattering points to use for instancing existing unreal assets. The tool instances the geometry correctly, until I add a pscale attribute to the points which then causes the instances to disappear. If I bypass all the other geometry and only have the points be output, then the instances work correctly along with using pscale. This clearly seems like a bug, but perhaps it's related to some functionality I'm unaware of.
Anyone successfully using pscale to drive instances along with standard geometry creation?
I'm still not getting much luck with this. Anyone from Side FX able to comment?
same pb here, are you using Houdini Engine V2 :/
Edited by lealexandrebreton - Feb. 15, 2021 08:17:27
Yes, using the latest version of the plugin.
Well, I found the issue in case anyone else runs into it. Clearly is a bug, but if you move the instance points to be the first geometry in your final merge node, then the instance works. Mine was initially the last input to the merge node and therefore for some reason it's attributes were being ignored.
