CHOPs audio questions
   2185   2   0
I'm doing a thing with CHOPs where I use some music to sync some procedural anim. Looks good when I play back in Houdini, it looks good when I play back in mplay loading the audio there.
However, I can't get it out of Houdini and made into a movie with the audio synced. If I export from mplay, it fails with various errors, ("library configuration mismatch" -- even without audio).
So using ffmpeg, I convert the image sequence to a movie, then bring it into kdenlive, add the audio clip, and it quickly goes out of sync.
Same thing if I try to just insert the audio into the completed QT file using ffmpeg command line.
I imagine there is some kind of sample rate thing going on, but I don't know where to start. Anyone have any thoughts on this?
Thanks,
SeanQ
Sean Lewkiw
Machine FX - Cinesite MTL
I assume you checked the obvious, FPS. Houdini defaults to 24fps. Perhaps kdenlive is running at 30fps?
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Enivob
Yes, tried that, doing some more experiments today though.
Sean Lewkiw
