See attached image... I have a scene in which the Horizontal Aperture parm on a camera LOP gets disabled after a certain frame. The logic for disabling the parm is clearly tied to the state of the control parm above, so I'm really confused on this one, as my control parm is not set to None or Block.
What can cause a parm to be disabled on a certain frame like this? No Keyframes anywhere. The camera lop is in edit mode, pointing to an incoming USD camera that is perfectly fine if not affected by this camera lop.
This is in 18.5.462.
Camera LOP: Aperture parms disable after a certain frame
2567 5 1-
- Tim Crowson
- 250 posts
- Tim Crowson
- 250 posts
- jsmack
- 8173 posts
- mtucker
- 4559 posts
If you can post the hip file with the bad camera LOP in it I'm sure there's some reasonable explanation, but you've got me curious... You can probably delete everything in the scene except the camera LOP. Or if you want to explore for yourself, I'd say @jsmack's suggestion is likely the best bet. You can unhide all invisible parameters to see if there are some weird expressions or keyframes that got put in there by accident?
- Tim Crowson
- 250 posts
The hidden parms don't drive the visible ones though, it's the other way around, right?
I'll see if I can extract the node, but I should add that it has an expression on it that is reading USD attributes on the camera prim directly, so you'd need the camera too, which may or may not be feasible. I'll see how far I can whittle it down.
- Tim Crowson
Technical/CG Supervisor
- jsmack
- 8173 posts
