Create skinprim attribute for curves?
6523 5 1-
- BrianHanke
- 455 posts
Howdy all, I've got some FiberMesh curves brought in from ZBrush and Houdini needs skinprim and skinprimuv attributes to recognize them as hairs for clumping, etc. I see that skimprim is just the primitive that a hair or guide is connected to. skinprimuv I have no idea. Is there a way to create these attributes? I can resample the curves to get curveu, giving me the root, but I'm not if that's on the right track and what to do next. Any tips are welcome, thanks!
- tamte
- 9379 posts
- BrianHanke
- 455 posts
tamte
use Guide Skin Attribute Lookup SOP and plug your guide curves and skin to it
it will create lookup attribs if missing
Nice, thanks! That sets the attributes up and all looks good in the geo spreadsheet. However, the hairgen isn't picking up all the guides for some reason. I tried a bunch of things, but no luck. Project is attached if anyone wouldn't mind taking a look. Thanks again!
Edited by BrianHanke - March 4, 2021 18:16:52
- BrianHanke
- 455 posts
Still playing around with this and it's just not working no matter what I do. My original sample had some guides cutting through the geo, so I can see how the attributes are being created incorrectly there. But even with a flat plane and some curves heading straight up Houdini still can't figure it out. Everything looks okay in the geo spreadsheet, everything that needs to be there is there, but it's not assigning the skinprim and skinprimuv attributes correctly...
- tamte
- 9379 posts
your curves are reversed, the roots are on the ends further from the skin
so append Reverse SOP right after your curves File SOP
you may also need to increase Influence Radius on Hair Generate since your guides are pretty sparse
Edited by tamte - March 5, 2021 12:04:27
- BrianHanke
- 455 posts
tamte
Ha, amazing, so simple. Thanks very much!
