How to change the default .shelf file?
   2487   3   0
I'm creating tools into my jerry.shelf file.
But when I opening the dialog it always points to the default file.
How to change it to my own file?
Edited by jerry7 - March 12, 2021 05:47:05
If you change "Save To" file and Apply/accept then it should move the tool to that new file. I just tried and it worked fine.
rafal
Thanks for reply!
Are there any setting to change the default path permanently?
Does it be hard coded in app or written in a setting file?
You can try setting `HOUDINI_TOOLBAR_PATH` env var, or `HOUDINI_USER_PREF_DIR`.
https://www.sidefx.com/docs/houdini/ref/env.html [www.sidefx.com]
