Pivot reset
   1727   1   0
Guys, this is very simple but I am struggling with pivot control. Is there an way to reset pivot in every access level? Thanks in advance..
I am not sure what you meant by every access level but I think the answer to your question might be one of the below:
After your object, put a Transform SOP. Inside it, you'll see a Pivot Transform tab and under it write this to the Pivot Translate boxes: $CEX $CEY $CEZ
Or the answer you are looking for might be to click Move Centroid to Origin button inside the Transform SOP. (under pre-transform tab)
Hopefully it'll work.
