Issue when exporting a KineFX skeletal mesh to unreal
   5641   5   3
Hi, I have an issue with exporting a KineFX rig to unreal.
I setup a door and animation, but when I export the skeletal mesh some part of it are disappearing.
Unreal complains about bone missing from the bind pose but the skeleton I sent to the ROP FBX Character export does contains the bones.
Only the root_lock_right and root_lock_left bones don't have weight associated to them, but their children do.
So, in Houdini all is fine, bones, skinning, animations, but the unreal imported skeletal mesh is off.
I don't know where to look to debug this, how would you fix or investigate this?
In Houdini:
Houdini export graph:
Import in unreal:
Houdini file:
door.hiplc (818.0 KB)
Hey Voktu,
I examined your scene and scratched my head, too. I haven`t found anything "wrong" that could cause the issue. Have you found something yet? Maybe unreal doesn't support weighting on bones containing the word "root"?
Cheers
CYTE
Edited by CYTE - April 22, 2021 02:49:08
Yes, I finally found the issue!
In the output FBX, the bones and meshes are mixed in a single hierarchy, which is bad practice and not recognized by unreal.
A simple fix is to prefix all of the joints name with 'rig:', ('rig:door_left', 'rig:root_lock_left', ...).
In that case, you will end up with two hierarchies that are correctly recognized.
Glad to hear you find it, and good to know!
Hey there! This is a dummy simple question but how did you go about renaming the joints before exporting from Houdini?
reparentjoints
Screenshot 2022-09-20 162929.png (1.2 MB)
